tps wiring
tps wiring
Hello all, I am running a 2.0 zetec on R1 carbs and tps with a megajolt from Chester Sports cars....I have lost my info and want to conect the tps up I know which is the +,- and mover on the tps unit but am not sure which is which of the three wires coming fron the megajolt unit?? I have already wrecked 1 tps through wiring it wrong so want to be sure this time cheers Nick
Hi Nick and welcome to the forum. I believe the page you require is this
http://www.autosportlabs.net/MJLJ_V4_ve ... _operation
Hope this helps
Hope this helps
Funky Diver
If it has 3 terminals then it's a straightforward process of using a ohm-volt meter to find out which is the center leg (wiper) of the potentiometer and the respective ground / VREF connections. I think it's been posted here in the forums before on how to determine this; essentially you connect the meter to two connections and observe which way the resistance changes as throttle changes. If you find two terminals that don't change as throttle changes then you've found the two outer legs of the potentiometer. A simple process of elimination.
You want:
+5v
center leg
GND
with the resistance *reducing* between center leg and +5v as throttle opens.
You want:
+5v
center leg
GND
Funky Diver
Thanks Brent... *digs out meter and carbs*
Gives me summat to do in readiness for my kit arriving (not that I'm in ANY position to do anything with it all... car's in bits, literally!)
Following has been added later :
And all done
For reference
Kawazaki Ninja ZZR Keihin Carbs wiring colour is +5 = Yellow, Gnd = Black, TPS Input = Blue
And all done
For reference
