Hello,
after reading some articles about ignition timing, I intended to bring my new knowledge in an excel sheet which creates a map automatically by taking my inputs into consideration. At first sight it seems to work pretty well, although the map still needs some final fine-tuning due to rounding issues. Do you guys have any suggestions for improvement? Maybe regarding my english translations of the technical terms, too?
I also created the first map for my Ford crossflow engine with MAP sensor. I will test it on the road later. What is your opinion of the timing?
Greetings,
Dominik.
Selfmade Excel tool for mapping and Ford Xflow map
- Automatic mapping.xls
- Excel sheet for automatic mapping
- (41 KiB) Downloaded 723 times
- FordXflow_MAP.mjlj
- Ford crossflow map
1660ccm, Kent 234 cam, Twin 40 DCOE Weber - (802 Bytes) Downloaded 757 times
There has been a fault in one cell and nothing worked.
Now it is fixed...
Now it is fixed...
- Automatic mapping_V2.xls
- (42 KiB) Downloaded 738 times
