Supercharged 1293cc A Series
Post Supercharged 1293cc A Series
Engine Mfg: A+ Series
Engine Code: 12H
Cylinders: 4
Displacement (cc): 1293
Rev Limit: 7200
TPS or MAP: MAP
Boosted or Normally Aspirated: Supercharged
If Boosted- max Pressure (KPa): 68.948 (10 PSI)
Modifications: Stage 3 head, lightweight flywheel, kent cams 276, 1.5 ratio roller rockers, AE alloy pistons, SC drop gears 1:1, SC close ratio gearbox, 3.44:1 final drive ratio, modified HIF44 carb.
Chassis: Classic Mini
Notes: This was set up on a rolling road, I paid 250 so you guys best be greatfull! Wink
If you want the actual file, PM me.
 Description:
 Filesize:  11.16 KB
 Viewed:  7505 Time(s)
View user's profile Send private message MSN Messenger
I put this in to a A4.0.2 Format as I am looking for base line maps for my Supercharged project and this looked to be a good starting point as the NA portion looks similar to my NA pas at the moment. I am trying to build a library of just Forced Induction maps to study.
 Description:
 Filesize:  106.41 KB
 Viewed:  7281 Time(s)
A Series 1293CC Supercharged.mjlj
 Description:
Download
 Filename:  A Series 1293CC Supercharged.mjlj
 Filesize:  807 Bytes
 Downloaded:  680 Time(s)
Respectfully
Dean
Many Thanks for posting this map,this has sorted so many of my running problems
I no longer feel like scrapping the little rust bucket Very Happy
WOW!!!!! I forgot I made this map up!!!!! Glad it helped.
Respectfully
Dean
