I've been running an MJLJ on my mini for about 2 years, runs great, love it - my father is in to Morris Minors, and has one running dual fuel with LPG. I offered to install a MJLJ on it so that he could run a Petrol map and an LPG map. Good plan right.
So I soldered up a kit, made a loom and installed it this weekend. The bastard just won't spark - I've checked and re-checked every wire, and can't figure it out. I wired the EDIS to MJLJ loom with the same connectors as in my mini, and have swapped as much as I can between the cars, but unfortunately I have my engine in pieces, and can't compare voltages etc. which is a real pain.
I disconnected the MJLJ to rule out a fault there (putting the EDIS in 10* limp home mode). There is about 2.5V AC across the VR sensor when cranking, and I've tried reversing the connections - no good
The only thing that doesn't check out is that according to the Installation Guide, I should have 12V on pin 1 of the EDIS - I don't - but I've tried the EDIS from my mini and it's the same.
My boss offered me the little portable oscilloscope to bring home for the weekend, but I forgot to grab it
if anyone has any clues, I'd love to hear them
thanks
