Hello
I started the installation of the EDIS / Megajolt on my 64 Corvair today. I was planning to use the ac / smog pulley and mount the trigger wheel to it. The teeth will extend beyond the pulley about 1/4". I am concerned that this may not be enough clearance for proper operation.
Do you know if there is a preferred distance that the teeth need to extend? Does this look like it would work or am I apt to get an errant signal since the teeth are so close to the pulley?
Thanks for the advice.
How much Clearance is required for trigger wheel install
- DSCN4236.JPG (189.18 KiB) Viewed 6263 times
- DSCN4238.JPG (167.24 KiB) Viewed 6263 times
- DSCN4239.JPG (172.33 KiB) Viewed 6263 times
Keith
63 Spyder Coupe (temporary surrogate owner)
64 Monza Convert 110 4-speed
69 911T (IROC Clone)
"Horizontally Opposed"
Darien, IL and Boyds, MD
