megajolt connection
Swedge
megajolt connection
Post by Swedge »
my laptop dosnt have a rs232 port on it, will it be fine using a usb converter?
Swedge
Post by Swedge »
ok ive found the rs232 - usb cable from trigger wheels but does anyone know where i can buy a rj11 - rs232 converter thats already wired up?
Swedge
Post by Swedge »
is this pre-wired?
http://www.autosportlabs.com/rj11-seria ... -p-43.html
how long does shipping to the uk usualy take?
luxseven
Post by luxseven »
If all else fails, consult the manual.
My blog: http://jacob-jos.blogspot.com/
Swedge
Post by Swedge »
yeah i noticed that but i need the rj45 - serial connector and noticed autosportlabs sell them as trigger wheels dont
just wondering if thier pre-wired
ive just recieved an email saying they are pre-wired but the adapter wont work on windows 7 which is what im running :(
alexander
Post by alexander »
IMHO, any converter involving the USB port on your laptop stands a good chance of being a big headache. if you laptop has a PCMCIA (older) or Express Card (newer) slot, buy a card with the appropriate socket on it eg DB9, and use that. they always work. you will find hidden on this site, plenty of posts expressing frustration with DB9 - serial converters which just dont work.
luxseven
Post by luxseven »
When I bought mine, there was a RJ11 to RS232 adapter delivered with. You can buy them separately in any electronic's shops, the wiring is available in the manual. From there you go to the serial to USB converter. Worked fine for me. Be sure to buy a converter with the FTDI-chip.
Cheers.
Jos
Swedge
Post by Swedge »
ive purchased the rs232 - rj11 adaptor from the shop but thier usb converster dosnt run on windows 7
i managed to get one in the uk that is labelled up for windows 7 so hopefully it all works
luxseven
Post by luxseven »
Thanks for keeping us updated.
Tell us what brand and model and if it works.
@brent
Maybe time to edit a "sticky" thread with the converters that work/don't work. This is quite a recurring problem and lots of people seem to run into the trap. I suggest a sticky post on top of one of the forum sections indicating brand and model of the converter and the operating system it runs with.
Cheers.
Jos
Swedge
Post by Swedge »
my megajolt will be running this :)
Swedge
Post by Swedge »
the adapter ill be hopefully using looks the exact same as the 1 on the shop but ill post back when i get the make and model
Swedge
Post by Swedge »
Swedge
Post by Swedge »
recieved my serial-usb converter from ebay today and this is what is it says in the drivers.txt
PL-2303 Driver Setup Installer, Prolific Edition
Setup Installer Revision Note History
System Requirement:
. Supports the following Windows OSes:
- Windows 98SE
- Windows ME
- Windows 2000 SP4
- Windows XP SP2 and above (32 & 64 bit)
- Windows Server 2003 (32 & 64 bit)
- Windows Server 2008 / 2008 R2 (32 & 64 bit)
- Windows Vista (32 & 64 bit)
- Windows 7 (32 & 64 bit)
NOTE: For Windows 7, please use RC build 7100 or above.
. USB host controller
. Device using PL-2303H/HX/X version chip
Supported device ID and product strings:
. VID_067B&PID_2303 for "Prolific USB-to-Serial Comm Port"
Release Notes:
PL2303 Driver Installer v1.1.0
Changes from Installer v1.0.6.26:
Driver Changes (no change from last installer) -
- Windows 98/ME Driver: v2.0.0.19
- Windows 2000/XP/Server2003 (32 & 64-bit) WDM WHQL Driver: v2.0.13.130
- Windows Vista/7/Server2008 (32 & 64-bit) WDF WHQL Driver: v3.3.10.140
Installer Changes -
- Fixed cannot run installer program in Windows 2000 SP4.
- Change version numbering format based on Installshield 3-digit format.
Installer & Build date: 1.1.0 (2009-12-02)
Language Support:
- English (default)
- Chinese (Traditional)
- Chinese (Simplified)
- Japanese
Prolific Technology Inc.
http://www.prolific.com.tw
ive read to use it with megajolt it needs the p2303 chipset which it looks like it has and works with windows 7 so hopefully it will work with megajolt
installed the drivers and its finding it under com port 3 so looks like its working with windows 7 64bit
