I have recently bought a class 5 autograss car running a vauxhall 1400 engine and megajolt lite jr. I was wondering if there was any way that you could have a single adjustable parameter on a button whilst already having 2 different maps on a switch. For example I am looking at wiring a button in so that i can sit on the line with my foot flat to the floor but sat at exactly the right revs because it is being limited, but then as soon as i let go of the button for the rev limiter to return to the setting desired whilst racing.
Any help would be greatfully recieved
Adjustable rev limiter
patrickduncan
Hello,
You can configure the Option Input to switch between two different ignition configurations on the fly. that will let you specify a different rev limiter setting for each configuration.
See the Operation and Installation guide for more information on enabling this!
You will probably need the Hard Rev Limiter module to get best effect; without the hard rev limiter the controller enacts the 'soft limiter' which retards the ignition to zero degrees 100 RPMs before the hard rev limiter cuts in.
Let us know how it works out for you!
patrickduncan
patrickduncan
patrickduncan
if the hard rev limiter is mounted externally from the megajolt you could use one of the additional user outputs as a secondary way to trigger the hard rev limiter, with a switch in-line to disable it. That way, it would be normally be triggered by the standard hard rev cut-off, then optionally triggered by one of the extra user outputs with an in-line switch.
I think a quick diagram is needed. let me get back on that
patrickduncan
