Dear all,
many apologies if this has been covered before - but I am struggling to find the answer to my problem.
I am running a MJL V3 (acquired fully built and tested supposedly). Having connected the unit up everything seems OK - car fires and runs much better than before even with the map it came with which is almost certainly wrong for my car. However, I cannot get a PC to talk to the MJ - getting the dreaded message
"Timeout reading cylinder count" .
The only thing is, I am using the serial port on my PC. In fact, I have tried two different laptops (one running XP the other running W2K - both with same issue.
Most of the posts I have seen on this subject relate to problems using USB adaptors.
So - please can someone tell me if there are some basic things that need to be set up to run with a serial cable?
Thanks in advance
Mark
Problems with serial connection
MarkDeTriomphe
Triumph Spitfire 1300 with Megajolt Lite, V3 - not quite running yet
MarkDeTriomphe
