Hi everyone,
I just completed a very custom designed 3.4L Ferrari 308 road/rallye engine and employed the megajolt system to run things. Brilliant system, just what I needed but I've run into a problem. Max rpm on this engine is a bit north of 8000rpm and the system is cutting out on me at 7400-7500. I've ruled out it being a pinging issue because I can run this ignition timing (36 degrees) when peak torque occurs which is about 5800rpm with no pinging at all. Just to be sure I lowered things a great deal just to be thorough. I definitely believe the issue is with the EDIS V8 system itself not being able to rev this high. What do I do.
Any help would be much appreciated.
-john
Ferrari max rev issue
Ferraripilot
Ferraripilot
