Do I need to tap & fit one of these connectors into each of the 4 branches of the inlet manifold & fit a plenum chamber? If so which layout - 1 pipe connecting all 4 connectors & then into the plenum (so 1 pipe into the plenum) or a seperate pipe from each of the 4 connectors with each one going to the plenum (so 4 pipes into the plenum)?
Or can I just tap & fit one connector into one of the branches of the manifold - if so which branch (cylinder 1, 2, 3 & 4) & where on the branch (nearer the engine or nearer the carb)?
Or should I tap & fit one of the connectors into another part of the inlet manifold - near the brake servo take off for example?
Sorry for all the questions
