Coil wiring
locost27
Coil wiring
Post by locost27 »
Beofor I fire my engine up for the first time can you guys confirm which is the positive an negative terminals of the coil.
The coil plug is numbered from 1 to 3 thanks
thanks[/img][/url]
The center connection of the coil connects to ignition switched +12v; the other two connections connect to the EDIS module. You'll find a wiring diagram here in our installation guide. http://www.autosportlabs.net/MJLJ_V4_ve ... tion_guide
Hope this helps,
locost27
Post by locost27 »
Hi
Thanks for the reply. Sorry if I am being stupid but does it not matter which way round the plug is orientated ? or does it not matter as long as the supply is correct ?
locost27
Post by locost27 »
Hi
