Help
locost27
Help
Post by locost27 »
Hi
Prior to wiring in the magajolt unit I am trying to get te engine to run on the edis unit.
However all i get when cranking is banging and farting.
I'm assuming it's an issue with the firing order. The egine is a vauxhall red top where the firing order is 1342.
any help would be great thanks
dr.occa
Post by dr.occa »
Did you make certain that your plug wires are plugged to the coil pack properly?
1&4 fire together
2&3 fire together
AUTOSPORTLABS
NonStop Tuning
www.86garage.com
"Poverty is not a virtue."
locost27
Post by locost27 »
Just realised my mistake.
On placing the trigger wheel against the sensor I didn't roatate the whel n teeth.
