Off the shelf trigger wheel for Gen 1 SBC?
hefty lefty
We are building a natural gas truck and I want to run this ignition on it. I gather that it's pretty easy to drill the harmonic balancer for the pattern, if you have a dividing head and a vertical mill and a mill drill, or space the front crank pulley out but then you have to move the accessories forward or shorten the pulley, or turn the OD and shrink it on. Unfortunately, I'm working with next to no fabrication facilities whatever. Is there an off the shelf setup that's a bolt on or a 72-2 distributor wheel for this, the commonest of all engines on planet now that there aren't THAT many aircooled VWs left?
