Feature suggestion: Autocross start/finish set by phone
Moderators: JeffC, stieg
int2str
Post by int2str »
On a typical autocross, the start/finish gates cannot be stopped at to acquire a starting & finish location. A nice feature would be if the driver could use his/her GPS enabled smartphone to walk to the start & finish gates, mark both and then go back to the car and transfer these coordinates to the RCP to be used.
Also, in another thread there was a suggestion to start AutoX timing based on G-force. I would highly discourage this, since the start timing gate is usually not right at the starting line, but a few feet in. To get more accurate timing that matches the event timing, it should only start when the GPS marked starting point is crossed + G-forces are there (to prevent false starts due to GPS).
These are great points. Agree that a combination of g-forces + GPS coordinates are necessary for detecting launch point.
andylaurence
Post by andylaurence »
Interesting. Autocross is clearly different to competitive events here in the UK. Over here, the car is lined up with the timing beam (within 10cm) for sprints and hillclimbs, whilst AutoSolo is usually timed by stopwatch from the moment the car's wheels start spinning. Using longitudinal G >0.3 and within 10m of the starting point usually does nicely for comparing runs.
Sprinting an ADR Sport 2
www.endurancelay.co.uk
Jaynen
Post by Jaynen »
All autocross I do is beam timed but you stage about 1 car length before the beam
