I have not yet found a method to plot distance vs. speed. Am I missing something?
Justin
Distance vs. Speed
dimondjack
I +1 this as well.
I currently use Excel for calculating distance and speed. I'm using an average of two data points times the time delta between the two. It works ok, but I'm getting some decently large variation in lap length (say 3%) which is under my time differential between laps. I'm pretty sure my line does not change by 3% per lap, so I'm looking for other reasons for the difference.
One potential I've noticed are GPS spikes and dips for speed as I go around corners. I'm going to work on filtering these out, but they are a different problem that we'll have to work on.
Hi Apexed,
It's in our Version2 firmware branch that we're currently testing. The distance calculated will either be a total distance for the datalogging session, or a distance that resets to zero if a start/finish line is configured.
The distance calculations are part of the predictive lap timing algorithm feature, which is needed for the android dash. Watch for some news on that very soon!
