Request for proper time data in recording files
Got a burning desire for a new feature? post it here!
Moderators: JeffC, stieg
GTIspirit
Post by GTIspirit »
For a future release could there be a proper time scale recorded in the logfile? I'd like to have a proper time axis in the log files.
Not a timescale from the GPS satellites, but rather a time scale from the internal clock. So 0s would be when the recording stops and the time column would have a proper time stamp from the internal clock on the row where the data was recorded. So if all rasters were set to 10Hz the time column would basically have 0, 0.1s, 0.2, etc. Odd measure rasters would of course have time stamps in between.
rushy
Post by rushy »
+1
neoraptor
Post by neoraptor »
+1 !!
And it is quite easy to implement.
gizmodo
Post by gizmodo »
Bumping this because I'm fighting with logs and RaceRender right now.
stingg
Post by stingg »
Agreed with this. BUMP!!!!
So we're looking at adding this in the big V2 firmware update.
Looking at a format of SSSS.SSS ?
gizmodo
Post by gizmodo »
I think that would work, something that starts at 0 when the log starts and counts up from there.
GTIspirit
Post by GTIspirit »
brentp wrote:So we're looking at adding this in the big V2 firmware update.
Yes. Only needs to have as many decimal places as the fastest available sample rate. So if RCPro only does up to 100Hz, which is every 0.01s, then only needs to be SSSS.SS, with increments of 0.01s, no need for 0.001s increments or? At the other end, how many seconds should it be capable of, depends on how many seconds of data people take for Lemons or ChumpCar or other endurance events.
G111ORH
Post by G111ORH »
Did this ever happen ?
fmbo
Post by fmbo »
+1.
torkey
Post by torkey »
+1
