My RPM signal on my MR2 is not clean enough even though it is circa 5v taken from the ECU.
Will the coilX work even though is quite a low voltage "unclean" signal? -no where near 400v!
Many thanks.
Phil.
CoilX
CoilX Installation Difficulties
Brent,
I ordered CoilX and installed it Saturday prior to a race on Sunday. The application is a 2 stroke Honda 125cc engine on a shifter kart. The CoilX instructions detail connecting to the negative side of the coil and and the other to ground. There is no 12v source feeding the coil, only a ground and +, (coil is like this)
![Image](http://i.ebayimg.com/00/s/MTAwMFgxMDAw/z/NSAAAMXQhuVRXG-m/$T2eC16NHJHEE9ny2qTM3BR%28G-lLm+g~~60_12.JPG)
I connected the ground of coilx to the ground on the coil, and the Coilx "Coil" wire to the + wire going into the coil from the ignition. I don't have access to an ocilloscope to check whats coming out of these. RCP is run off a 12V battery pack that is only connected to RCP.
In the software I enabled the RPM and tried the clock divider of CLOCK/128 and CLOCK/32 and got no data either time, just zeros.
Any ideas on how I can get this to work properly?
-Ray
-Ray
The CoilX module is designed to work with a conventional coil as gizmodo described, where the spark is triggered by the negative going pulse on on input to the coil pack, with the other coil pack connection tied to +12v.
ohiokm11, so your coil pack is essentially opposite of that, with ground fixed, and the 12v pulse providing the trigger?
That's correct Brent. The ground wire is grounded to the engine and the ground from the ignition box mounts to the same location. The + wire goes into the coil. I'm not sure that it is 12V though as there is no battery in the system, there is just a stator as shown below.brentp wrote:The CoilX module is designed to work with a conventional coil as gizmodo described, where the spark is triggered by the negative going pulse on on input to the coil pack, with the other coil pack connection tied to +12v.
