I recently started working on fitting a Race Capture Pro in our team racing car.
We initially had trouble programming it and also problem with the real time sensor display in Race Analyzer
We tested it with 2 computers in the garage to no success. I figured i might as well try it on my workstation at home and did so.
The flash and sensor monitoring surprisingly worked!
After some thinking I actually stumbled upon the answer, my computer at home is running an english version of Windows while the computers in the garage are running our native language (Swedish).
So after switching the main computer in the garage over to American numerics With decimals divided by a full stop as you use in America instead of the local way with splitting it with a comma I could flash it successfully!
Is this something you guys will look into and maybe change so that we can input commas againg without having to actually change it in windows?
Thanks in advance for your reply!
Also if you need any more information or anything is unclear, I will gladly provide you with more information
