Coolant Temp Sensor - Aux Input
Dazman1360
Post by Dazman1360 »
I want to start using the advance correction part of my MJ ECU, I have fitted a standard GM Style Coolant Temperature Sensor. These are the values as provided by the suppler of the sensor.
2 Celsius = 4000 ohm
74 Celsius = 362 ohm
94 Celsius = 212 ohm
To be honest I don't really understand or know how to get the values above onto the ECU.
Can someone help?
Many thanks
There are users here who have adapted the GM coolant sensor to the Megajolt using the built-in 2.2K pull-up resistor, you can find their post if you do a bit of searching. Essentially the values are loaded into the mapping configuration for the auxiliary channel.
If you get stuck, let us know and we can help you out.
