RaceCapture app freezes when uploading config
Report any thing that looks like a bug or problem in the system here
Moderators: JeffC, stieg
GTIspirit
Post by GTIspirit »
I'm trying to get my Mk1 RCPro hardware updated with the new RaceCapture app. But either the hardware of the app freezes about 2/3rd of the way through the config upload.
What's wrong with the .rcp config that's causing the hardware to freeze the the red LED to illuminate?
first_initial.rcp.txt
RaceCapture app config to reproduce last valid RaceAnalyzer config. (Delete the .txt filename, workaround because forum doesn't like .rcp format.)
(17.06 KiB) Downloaded 1150 times
20150531_Configuration.rcap.txt
Last RaceAnalyzer config, trying to get this put into the V2 RaceCapture app. (Delete the .txt filename, workaround because forum doesn't like .rcap format.)
(10.91 KiB) Downloaded 1109 times
GTIspirit
Post by GTIspirit »
For comparison, this preliminary config worked, it successfully uploaded to the device, and downloaded from the device.
So why does this one work and the first_initial.rcp doesn't work?
initial_functional.rcp.txt
Preliminary config doesn't freeze when uploading to the device.
(17.02 KiB) Downloaded 990 times
GTIspirit
Post by GTIspirit »
Not sure which particular configuration setting was causing the app to freeze. I went through the configuration item by item, writing to the RCPro after each change so I could narrow down which configuration caused the app to freeze. Except none of them did.
So it's like the freezing was caused by trying to write too many changes at once? Maybe it prefers incremental changes rather than a whole bunch at once :?:
Only other thing I noticed was when trying to write from the script screen then it consistently froze. But when it was freezing the other night I wasn't on the script screen.
So in the end this config ended up working, and this config is nearly identical to the one I previously reported caused freezing.
first_valid.rcp.txt
First valid/functional config.
(17.06 KiB) Downloaded 1008 times
GTIspirit
Post by GTIspirit »
^bump for a solution.
The freezing is particularly prone to happening when making scripting updates.
Ls_Rx7
Post by Ls_Rx7 »
Bump. This was happening to me earlier today when trying to add a script.
Sorry for the late reply! Is this still happening with the latest firmware (2.8.5) and the latest app? (1.3.13) ? you can download both from http://www.race-capture.com/software.
Ls_Rx7
Post by Ls_Rx7 »
I downloaded 2.8.5 and 1.3.13 and no longer have the issue.
Great, thanks for the update!
