pins on EDIS?
andre saethern
pins on EDIS?
Post by andre saethern »
Whats pin 2 and 4 doing? also that brown and green wire going through the coil connector, whats that for?the radiothingy?
andre saethern
come on, somebody must know
come on, somebody must know this?
MartinM
Well....
Post by MartinM »
Well....
1) ...if you look at the diagrams in
http://picasso.org/mjlj/?q=node/757
then pin 2 and 4 do nothing on 4 and 6 cylinder installations
2) What brown and green wire? The coil connector has three wires. Mine are black, green/red and green/yellow
3) If you mean the radio suppression capacitor, then that's what it is. It seems to be optional and may or may not be present in the donor car that you get the EDIS from. I haven't got one, but there again, I have no radio anyway!
NigelB
Which EDIS 4 6 or 8 ?Nige
Post by NigelB »
Nige
Magnolia
wire identity
Post by Magnolia »
If you are talking about the center coil lead, it's +12vdc.
It is actually red/green but yours may have aged the red to look like brown. The wiring is clearly identitified in the installation part of the manual which is just a few clicks away under Project Information Library. Hope that helps.
Svein
4 cylinder EDIS module
Post by Svein »
Found this in my Megajolt folders, unknown source ????
4 cylinder EDIS module pinout Signal EDIS Module Terminal
PIP (EDIS output signal) Pin 1
IDM (diagnostic signal to ECU) Pin 2
SAW (ECU spark control signal) Pin 3
IGN GND (signal return) Pin 4
VRS - (crank sensor negative) Pin 5
VRS +(crank sensor positive) Pin 6
VRS shield (crank sensor shield) Pin 7
VPWR (ignition switched 12 volts) Pin 8
PWR GND Pin 9
COIL 1 (coil drive) Pin 10
CTO (clean tach out) Pin 11
COIL 2 (coil drive) Pin 12
6 Cylinder EDIS module pinout Signal EDIS Module Terminal
PWR GND Pin 9
COIL 2 (coil drive) Pin 11
COIL 3 (coil drive) Pin 12
8 Cylinder EDIS module pinout Signal EDIS Module Terminal
VRS - (crank sensor negative) Pin 4
VRS +(crank sensor positive) Pin 5
VPWR (ignition switched 12 volts) Pin 6
IGN GND Pin 7
COIL 1 (coil drive) Pin 8
COIL 2 (coil drive) Pin 9
PWR GND Pin 10
COIL 3 (coil drive) Pin 11
COIL 4 (coil drive) Pin 12
andre saethern
since pin 2 and 4 isnt used
since pin 2 and 4 isnt used is it okay for me to take the pins out and use one of them in space 11 for the rev counter as I am missing that one?
Magnolia
unused pins
Post by Magnolia »
Sure. Don't know how to take them out of that connector though, not sure a molex removal tool would work. Maybe you already figured that out.
andre saethern
That was no problem at all,
That was no problem at all, just used a kitchen knife. :D
