My EGT setup has a couple problems. First the temps it is reading is much lower 300-400 degrees than what my stand alone gauge shows. And the response seem very sluggish compared to the stand alone gauge. The temps climb much slower. 10-15 second delay which could be deadly.
Any idea what could be going on here?
The amplifier I am using is:
http://www.adafruit.com/product/1778
The sensor is a K-type thermocouple.
EGT responsiveness
Hi Torkey,
Sorry to hear you are having issues. Unfortunately I don't know enough about how you have this setup with your Race Capture to provide useful feedback or ideas. Can you elaborate more on the setup so we can understand it better? TIA.
Andrew Stiegmann (Stieg)
Principal Engineer
Autosport Labs Inc.
Principal Engineer
Autosport Labs Inc.
Hi Torkey,
A couple of questions:
At what temperatures is it reading low? Is it a temperature below 680? If so have you tried removing the 0:0 measurement?
How are you reading these values. Do you have an RCP in car and are reading the values on a tablet that is connected to the RCP unit via Bluetooth? Or are you using some other method?And the response seem very sluggish compared to the stand alone gauge. The temps climb much slower. 10-15 second delay which could be deadly.
How did you figure out these calibration values exactly? Did you read the gauge and measure voltage on the line? Did you use a sender spec sheet?it is calibrated using these values:
0 0
350 1.7494
680 3.4625
790 4.0226
900 4.5687
So this would imply that you have a EGT gauge and sender setup and you are splitting the EGT sender signal wire between the RCP unit and the gauge itself. Is this accurate?First the temps it is reading is much lower 300-400 degrees than what my stand alone gauge shows.
Principal Engineer
Autosport Labs Inc.
Principal Engineer
Autosport Labs Inc.
I do have a tablet in the car connected to RCP over Bluetooth.
The calibration values are based on the information provided with the thermocouple amp. (see attached image)
There are redundant EGT probes at this point. One is connected to the RCP and the other is connected to a GlowShift EGT gauge. I don't have a way to validate the readings of either one unfortunately. The GlowShift seems more believable at this point.
I've tried a couple of different thermocouples thinking that maybe I got a bad one but the results are the same. I don't think the problem is with RCP. But I have no idea how to get this to work. I know I can go in and fiddle with the calibration until the numbers are close but it's more the responsiveness that concerns me. Since this is a diesel, EGTs are a critical tuning metric and getting them wrong will kill my turbo and valves.
Are all K-type thermocouples the same? Do they make a fast response type? It's not just the delay in the tempos climbing but there is a significant delay in the temps falling too. I'm pretty sure it's the thermocouple but I've tried 2 and have had the same results.
- Screen Shot 2015-11-19 at 8.04.03 AM.png (100.9 KiB) Viewed 10822 times
No. They can have different resistance values and different scales of response. But they should be similar in terms of response properties (ie they all respond linearly in the case of an ideal K type sender). How they respond is what really matters for accurate readings.Are all K-type thermocouples the same?
Should be fast enough (read within a second or so... but that is what I have seen in practice, YMMV).Do they make a fast response type?
A few things that come to mind:I'm pretty sure it's the thermocouple but I've tried 2 and have had the same results.
- Your 0 0 mapping you previously described is wrong. It should be "0:1.25" since the output formula on the amp is T * .005 + 1.25. So if T is 0, then Vo is 1.25.
- Check that you aren't confusing Fahrenheit and Celsius. A quick search on Google shows that the GS EGT gauge reads in units of Fahrenheit (http://www.glowshiftdirect.com/Tinted-7 ... Gauge.aspx) whereas the amp outputs its values in Celsius (previous picture). Be sure you are comparing apples to apples
- Check that the wires leading to the temp probe are new and in good shape along with the probe itself. As wires and probes get used and age, their wire characteristics change, which can cause low reading values (although not nearly as bad as what you describe).
Principal Engineer
Autosport Labs Inc.
Principal Engineer
Autosport Labs Inc.
torkey wrote:There are redundant EGT probes at this point. One is connected to the RCP and the other is connected to a GlowShift EGT gauge. I don't have a way to validate the readings of either one unfortunately.
Ideally you'd be able to put a voltmeter on the output of the blue board and see how quickly the voltage changes. That'd let you pinpoint sensor or RCP as the issue. The AD8495 chip used on that board is plenty fast - will update 20k times a second (20kHz response).
Mechanically, if the TC is a small exposed sensor it'll react quicker. But EGT and harsh-environment TC's in a sheath have more mass, so they'll react a little slower. EGT shouldn't be as bad because there's a large amount of heat (not temperature) available to quickly change the temperature at the sensor.torkey wrote:I've tried a couple of different thermocouples thinking that maybe I got a bad one but the results are the same. I don't think the problem is with RCP. But I have no idea how to get this to work. I know I can go in and fiddle with the calibration until the numbers are close but it's more the responsiveness that concerns me. Since this is a diesel, EGTs are a critical tuning metric and getting them wrong will kill my turbo and valves.
I also disagree with the scaling chart you provided. This board has an offset so it can measure negative temperatures. The formulas are right on the back of the board : Vout = (Temp * 5mV) + 1.25V or Temp = (Vout-1.25) / 5mV so a simple 2-point curve (without correcting for TC nonlinearity) would be
0C at 1.250V
600C at 4.250V
750C at 5.000V
What power supply are you feeding the blue board? It'd do best with 12V battery voltage, not the 5VREF supply from the RCP connector. Otherwise it'll fall on its face as output gets near the supply. It's only specified to 0.1V below supply so the highest valid output would be 4.900V = 730C. On the other hand, RCP won't take a voltage higher than 5V..........
I did a post somewhere else here showing how to compensate for TC nonlinearity - I'll find that and come back & edit the post with a link.
Tom
Dangit.. Steig posted 9 minutes before I did, while I was still typing.
Same info though.
Here's that older EGT thread. http://www.autosportlabs.org/viewtopic.php?t=4518 This was for the same board, but I totally spaced on the offset feature at that time. So all my numbers need to have 1.25V added to them.
On the other hand, if you're unconcerned about EGT readings below freezing, you could just bridge across the 1.25V offset (the three-legged chip) or solderblob pins 2 & 3 of the 8-pin part together. That'll tie the REF input on the chip to common, so now 0C = 0V output. And 900C would be 4.50V, well in range of the RCP hardware, and happy to run from the RCP 5VREF output.
http://www.analog.com/en/products/ampli ... d8495.html
tom
tom
UPDATE
I gave up on trying to come ump with my own EGT sensor. Instead I went with this.
http://www.exhaustgas.com/ProductDetail ... 1056110.58
So easy. Worth the cost easily. I have a solid and reliable EGT sensor now.
