https://www.dropbox.com/s/kxmmuq7r8g7v3 ... s.pdf?dl=0
All I have to go by is this wiring diagram from a 2007 cbr (which I'm pretty certain is no different from the 2010 model I have).
So I would like to know how to proceed with caution given that firstly, the diagram may not 100% match the bike.
I can't tell if there is any information here that states if the data logger analog outputs are based on 12V as well as if there are any pull up resistors.
From my rusty electrical knowledge I was thinking I should try to use a multimeter on voltage detection to see if the pull up resistor is there or not and to check how high the voltage goes. Any advice?
