OBDII on which CAN Bus?
Blister202
Post by Blister202 »
Hi All,
Does it matter on which CAN-BUS you wire the OBDII coming from the car? First I had only wired the OBD plug on the car to CAN Bus 1 on the Mk2 and it worked. Now I have the OBD wired to CAN Bus 2 and another CAN Device is wired on CAN Bus 1. Now the OBDII channels don`t work anymore. My guess is I need to rewire OBDII to CAN Bus 1, is this correct?
Also ist the Mk2 capable of interpreting OBDII and Can Bus simultanously on both CAN lines?
Cheers
toga94m
Post by toga94m »
You need to edit your script to talk to the second channel. Hardware channel 1 is scripting channel 0, hardware channel 2 is scripting channel 1 (just subtract 1 from the number).
https://wiki.autosportlabs.com/RaceCapt ... _functions
These four examples are using CAN bus 1 (because of the 0)
https://wiki.autosportlabs.com/RaceCapt ... us_scripts
As long as your script uses the right channel, you should be able to use both ports in the same script. My MK1 only has the one channel so I can't prove it. :)
