Hi. Im in need of help. And getting relativly frustrated
Brandonorban
Post by Brandonorban »
Have my megajolt all hooked up and cant get it to communicate with the laptop.
The edis runs fine. But obviously stuck at 10degrees.
Ive tried a usb to serial converter with proper drivers installed and connecting to the computers serial port with a extention harness as the megajolt cable isnt deep enough.
According to the schematic for the adapter i should have had continuity from pin 5 to 3 and 4
I only had 3 so i went and modified the phone line to bridge 3 and 4
But a timeout message still comes up.
And i am trying to find the proper com but cant with the serial port as nothing says its connected. While the usb adapter itself does show up.
Hi, Thanks for posting. let's figure this out.
First, did you build your own cable or did you purchase the add-on cable we offer with the kit?
You can also try these Troubleshooting steps to see if you get any low-level communications to the unit. (Make sure the Megajolt software isn't running when you do these tests)
https://wiki.autosportlabs.com/Troubles ... lt_Lite_Jr.
Will watch for replies.
Brandonorban
Purchased your cable and adapter.
Ill have to see if i can figure out the troubleshooting tonight
Brandonorban
I dont understand hyperterminal. Or how to use it
I do have rpm coming out of the megajolt to my transmission controller
If you've never used it, this can help you get started.
http://www.techrepublic.com/article/ste ... -problems/
Basically our instructions in the wiki show how to use it as a back door to check communications with the megajolt system.
I saw your note; the cable we provide only requires 3 wires, it's not necessary to bridge the connections.
A fundamental check: When you power up the unit, do you see a green light? Assuming the system is completely connected (with PIP and SAW lines) do you see ignition advance vary as you vary RPM (using a timing light?)
Brandonorban
Still havent figured out how to use hyperterminal. But yes there is a green light on. And running the timing does advance as it gets rev'ed up
Brandonorban
So i followed the hyperterminal diagnostics and the megajolt responded as it said it should.
Turns out i somehow downloaded v3 pc software which was odd because when i went to their site there was only v4 available.
Its working good now tho. Thanks for the help!
Oh wow - we will need to ensure that's one of the first questions we ask. Good job figuring that out!
