I thought that I would start to learn how to write scripts in Lua however when I went to the setup, the Scripting menu is not displayed. Hmmm... any idea why the Scripting menu is not showing up?
Rich
RaceCapture App Script Menu missing
- Setup screen shot
- Screenshot_20170305-171745.png (62.01 KiB) Viewed 5089 times
PULSE/RPM SENSOR TUNING OPTION
i am using a RaceCapturePro mk3 when i connect it to the PC and open the RaceCapture App in my PC and go in setup potion i can not find Pulse/RPM sensor tuning tab in it. But i have dedicated input for RPM i.e. RPM1, RPM2, RPM3, RPM4. So if i want to tune this input according to my sensor what should i do. I am using latest Firmware too. Is there any particular script to get that tab in setup?. Also when i disconnect it from PC and then open the Software, the tab appears on its own. I am not getting this problem.
Please Help.
Thank You.
Please Help.
Thank You.
- RaceCapture.PNG (59.99 KiB) Viewed 5073 times
I had the same issue and Brent said its a known issue with RaceCapture 1.80 and the new RCP mk3. He said 1.90 will fix it and is due out any day now.
In the mean time he has a fix:
It's easy to edit the config file directly. Look for the section for "timerCfg". Edit the "sr" line to have a sample rate of either 0 (disabled), 1, 5, 10, 25, 50, 100, 250 or 1000 hz. Typically for RPM you'll want 10, 25 or 50 Hz.
Save the file, re-open it in the app and write it back to the unit. Hope this helps! The app will also have other dashboard improvements that we've been working on as well.
