Glad it is working.
What does the final script look like?
Help with shift light script
Here it is, I changed it for the ligths part to try to have them blinking. I used another script that was on the forum. Right now, they are only solid, but at least the work and I have RPM on the tablet.
FREQ_HZ = 30
loop_time = 1000/ FREQ_HZ
MAX_BLINK_PERIOD = 1000
DUTY_CYCLE = 0.2
--testRPM = 2000
LL1 = 6600
L12 = 7000
L23 = 7500
UL3 = 8000
function ctMAX(ll,ul,RPM)
factor = (ul - RPM) / (ul - ll)
blink_period = factor * MAX_BLINK_PERIOD
return blink_period / loop_time
end
function variblink(ll,ul,RPM,chan)
if j <= DUTY_CYCLE * ctMAX(ll,ul,RPM) then
setGpio(chan,0)
else
setGpio(chan,10)
end
if j < ctMAX(ll,ul,RPM) then
j = j + 1
else
j = 0
end
end
function setLight(ll,ul,RPM,chan)
if RPM < ll then
setGpio(chan,0)
elseif RPM >= ul then
setGpio(chan,10)
else
end
end
--the CAN baud rate
CAN_baud = 250000
CAN_chan = 0
--virtual channels
--addChannel( name, sampleRate, [precision], [min], [max], [units] )
rpmId = addChannel("RPM", 50, 0, 0, 8000, "RPM")
vltId = addChannel("EcuVolts", 10, 1, 0, 20, "volts")
gearid = addChannel("Gear", 25, 0, 0, 6)
iatId = addChannel("IAT", 1, 0, 0, 120, "F")
ectId = addChannel("EngineTemp", 1, 0, 80, 250, "F")
tpsId = addChannel("TPS", 10, 0, 0, 100, "%")
mapId = addChannel("MAP", 10, 2, -15, 25, "PSI")
injId = addChannel("InjectorPW", 10, 3, 0, 100, "ms")
ignId = addChannel("Ignition", 10, 0, -20, 20, "D")
knkId = addChannel("Knock", 1, 0, 0, 15, "count")
camId = addChannel("CamTiming", 10, 0, -20, 20, "D")
fuel2Id = addChannel("FuelLevel", 10, 0, 0,100,"%")
function toF(value)
return value * 1.8 + 32
end
function setRpm(value)
RPM = value
setLight(LL1,L12,RPM,1)
setLight(L12,L23,RPM,0)
setLight(L23,UL3,RPM,2)
return value
end
--offset/length in bytes?
--format is: [CAN Id] = function(data) map_chan(<channel id>, data, <CAN offset>, <CAN length>, <multiplier>, <adder>)
CAN_map = {
[1632] = function(data) map_chan(rpmId, data, 0, 2, 1, 0, setRpm) map_chan(vltId, data, 5, 1, 0.1, 0) map_chan(gearid, data, 0, 1, 1, 0) end,
[1633] = function(data) map_chan(iatId, data, 0, 2, 1, 0, toF) map_chan(ectId, data, 2, 2, 1, 0, toF) end,
[1634] = function(data) map_chan(tpsId, data, 0, 2, 1, 0) map_chan(mapId, data, 2, 2, 0.0145037738, -14.7) end,
[1635] = function(data) map_chan(injId, data, 0, 2, 0.001, 0) map_chan(ignId, data, 2, 2, 1, 0) end,
[1637] = function(data) map_chan(knkId, data, 0, 2, 1, 0) end,
[1638] = function(data) map_chan(camId, data, 2, 2, 1, 0) end
setTickRate(FREQ_HZ)
j = 0
function onTick()
--RPM=testRPM
processCAN(CAN_chan)
--setLight(LL1,L12,RPM,1)
--setLight(L12,L23,RPM,0)
--setLight(L23,UL3,RPM,2)
end
function processCAN(chan)
repeat
if id ~= nil then
local map = CAN_map[id]
if map ~= nil then
map(data)
end
end
until id == nil
end
function map_chan(cid, data, offset, len, mult, add, filter)
offset = offset + 1
local value = 0
while len > 0 do
offset = offset + 1
len = len - 1
end
local cv = value * mult + add
setChannel(cid, cv)
end
initCAN(CAN_chan, CAN_baud) Hey, glad you got it working. You know, you can take your script to the next level by moving the CAN mappings to the new direct CAN mapping scheme:
https://www.autosportlabs.com/racecaptu ... -released/
For now you'll need to pluck RPM via lua scripting, but you can move all of your other channels to the direct CAN mapping capabilities, which will lighten up your script and improve responsiveness.
For the blinking, I'm looking at this function:
if RPM < ll then
setGpio(chan,0)
setGpio(chan,10)
else
end
I'm a bit unsure of the conditions that would actually cause variblink() to be called. Do you have a link to the original blinking shift light script you found that ostensibly worked?
You could try to put a debug print statement righ before the variblink() line to see if it ever gets called:
if RPM < ll then
setGpio(chan,0)
setGpio(chan,10)
else
println("variblink!")
end
and then watch the RCP log for those messages.
if RPM < ll then
setGpio(chan,0)
setGpio(chan,10)
else
end
if RPM < ll then
setGpio(chan,0)
setGpio(chan,10)
else
end
Hi Brent, I used the script from GTSpirit. I'm using it for a base to improve that what I really want.
In the end, what I want is to have the lights to be solid while the RPM rises and the all lights to start blinking when RPM gets to 500 of the upper limit.
IE:
LL1: 6200 (Solid Green)
LL2: 6700 (Solid Green and Yellow)
LL3: 7200 (Solid Green, Yellow and Red)
LL4: 7500 (Blinking Green, Yellow and Red)
After that, I will be looking to have the Green and Yellow lights to blink individually as warning lights for Oil Pressur and Engine Temp, but that will be for later.
IE:
--virtual channels
SpeedGPS = addChannel("SpeedGPS", 25, 2, 0, 200, "KPH")
SpeedWhl = addChannel("SpeedWhl", 25, 2, 0, 200, "KPH")
-- CONSTANTS --
FREQ_HZ = 25 --1000/FREQ_HZ=loop time in ms. e.g. 25Hz=40ms--
loop_time = 1000 / FREQ_HZ
MAX_BLINK_PERIOD = 1200 --in ms (1000ms to 1500ms suggested)--
DUTY_CYCLE = 0.5
--testRPM = 5200 --test interface--
LL1 = 5000 --lower limit to start blinking light 1--
L12 = 6000 --sets light 1 on, starts blinking light 2--
L23 = 6500 --sets light 2 on, starts blinking light 3--
UL3 = 7000 --light 3 upper limit above which goes solid--
-- FUNCTIONS --
function ctMAX(ll,ul,rpm)
factor = (ul - rpm) / (ul - ll)
end
function variblink(ll,ul,rpm,chan)
if j <= DUTY_CYCLE * ctMAX(ll,ul,rpm) then
setAnalogOut(chan,10)
else
setAnalogOut(chan,0)
end
if j < ctMAX(ll,ul,rpm) then
j = j + 1
else
j = 0
end
end
function setLight(ll,ul,rpm,chan)
if rpm < ll then
elseif rpm >= ul then
else
end
end
-- Ini --
j = 0
-- RUN --
function onTick()
setChannel(SpeedGPS, getGpsSpeed()*1.61)
setChannel(SpeedWhl, getTimerFreq(1)*0.92)
RPM=getTimerRpm(0)
--RPM=testRPM
setLight(LL1,L12,RPM,0)
setLight(L12,L23,RPM,1)
end
