Organizing log files
Moderators: JeffC, stieg
anastos
Post by anastos »
Hi All,
When I log to the sd card the files all get default names like RC3, RC4 etc and I've found that the system will reuse a name (I had 2 RC7's on the card ).
What is a good method of giving them meaningful names? Do I need to rename them on the card before importing?
I haven't been able to locate the files after importing other than in the saved sessions list, and there I can not rename them. Where are the saved sessions stored after being imported from sd card?
Anastos
Hi, you can rename the files as you see fit.
When they are imported into the app, they're imported into a common database file.
You can rename the session by pressing the session edit button (looks like a notepad with pencil icon) once it's in the immediate session list (where you can select laps for viewing).
