With debugging on, I get the following log in the script window starting from plugging the RCP in. The log is the same whether the GP is turned on and Wifi enabled, or not. The log is showing some errors which make me wonder if the WiFi module is bad? Please let me know, Lucky Dog race coming up in 2 weeks
*** Start! ***
[watchdog] Initializing...
sizeof LoggerConfig: 13452
[CAN device] Initializing CAN0 with baud rate 500000
[CAN device] CAN init success!
[CAN device] Initializing CAN1 with baud rate 500000
IMU: init res=0
GPS: Initializing...
[OBD2] Init current values
BT: Detecting baud rate...
BT: Baudrate: 115200
timebase/logging/telemetry sample rate: 50/10/10
[lua] Initializing Lua state
[lua] memory usage: 16KB
[lua] Starting Lua Task
[wifi] Initializing...
[lua] Loading script. Length: 2636
[GoProWiFi] initializing
[GoProWiFi] send: AT+RST
GPS: provisioning attempt
[ESP8266 Driver] Client config unchanged by update
[main] Setup Task complete!
[ESP8266 Driver] Checking WiFi Device...
[ESP8266 Driver] Initializing Wifi
[esp8266] Version info:
AT version:0.40.0.0(Aug 8 2015 14:45:58)
SDK version:1.3.0
Ai-Thinker Technology Co.,Ltd.
Build:1.3.0.2 Sep 11 2015 11:48:04
[esp8266] Initialized
[ESP8266 Driver] Initialization successful
[ESP8266 Driver] Increasing baud to 230400
[ESP8266 Driver] Checking Client
[ESP8266 Driver] Retrieving Wifi Client Info
[ESP8266 Driver] Client is inactive.
[ESP8266 Driver] Checking WiFi AP
[ESP8266 Driver] Retrieving Wifi AP Info
[esp8266] get_ap_info_cb failed.
[ESP8266 Driver] Failed to read AP info
[ESP8266 Driver] AP is inactive.
[ESP8266 Driver] Checking Server
[ESP8266 Driver] Starting server on port: 7223
[USB] Starting telem stream on USB
[GoProWiFi] send: AT+CWMODE_CUR=1
[at] Unhandled msg received: OK
BT: Device responds at baud 115200
BT: Init complete
[GoProWiFi] send: AT+CWJAP_CUR="ScottBGoPro","5B074D46E9"
GPS: probing baud rate: 9600
GPS: Using baud rate: 9600
GPS: module detected at: 9600
GPS: Configuring baud rate to: 115200
GPS: Message was successfully received.
GPS: Configuring was successful.
GPS: detected current update rate: 1
GPS: Configuring update rate to 10: win
GPS: Configuring NMEA messages
GPS: Successfully configured NMEA
GPS: configure navigation data message interval: win
GPS: Configuring Gnss Navigation Mode: win
GPS: Disabling NMEA messages
GPS: Successfully disabled NMEA messages
GPS: provisioned
[ESP8266 Driver] Client connected
[ESP8266 Driver] Client got IPv4 address
[at] Command timed out
[esp8266] get_ap_cb failed.
[GoProWiFi] could not connect to GoPro
[ESP8266 Driver] Client disconnected
[at] Unhandled msg received: f`ffff~f`xfxxf
[at] Unhandled msg received: xfx
[at] Unhandled msg received: xx
