Hello.
See attach file.
I use 10Hz all sensor, GPS, CAN/OBD.
but my config file has 'sampleRate' 50Hz and lapCfg-sr 50.
why?
BUG? - sampleRate 50Hz fix
- 20180405.rcp.txt
- (15.79 KiB) Downloaded 440 times
That is weird, thank you for advising us.
You can fix this by:
* Reading Configuration in setup
* Go to GPS. Change Sample Rate to "Disabled". Then, change Sample Rate to 10.
* Write the config back to RaceCapture.
* Save the config file and verify your sample rates are 10 where they were 50 before.
Thank you, Let us know what you find out.
