Reply to topic Page 5 of 5
Goto page Previous  1, 2, 3, 4, 5
Raspberry Pi support - enables a hard-wired, dedicated dash
Thanks for the update.
Can you explain further w/r/t "Lose Connection" ?
If RCP loses GPS (e.g. you unplug the GPS antenna, for example. to force the issue)- and you lose all satellite) are you saying the RPi loses connection with RCP?
This should not happen *at all* - you should be able to connect to RCP regardless of the GPS status- and we've never seen that here. But if you can reproduce it reliably we'd be keen to fix it.
Founder, Autosport Labs
When initially powering on RaceCapture (RC) device via USB to the raspberry Pi the GPS status indicator on the top right of the screen will blink red and green while viewing the data channel screen.
Until the GPS status indicator stops blinking between red and green, the USB comm with the RaceCapture continually resets.
Once the GPS status indicator stops going red and starts blinking green then the USB comm connections seems to become stable and data on the screen continually updates.
If i do a warm start, ie. don't power down the Pi or RC then i don't get the issue. Its only from a cold boot.
Steps to reproduce are:
1. Power down the Pi and the RaceCapture
2. Ensure RaceCapture is plugged into USB port on Pi
3. Plug power into Pi and let boot up
4. Launch RaceCapture exec=sudo "opt/racecapture/run_racecatpure.sh"
5. In RC goto Dashboard
6. Observe behavior above.
Post Screen Going Blank
I should know this, but some how I can't remember how to do this, what are the steps to keep the screen on the Pi from turning off while running RaceCapture?
Thanks.
That description helps. So it is not actually related to GPS; it is an artifact of the connection being lost and re-established - the GPS icon only goes green if we have an active connection with GPS lock.
Try doing a factory reset - use minicom to issue the resetConfig on RCP's command line interface and see if that makes a difference. Be sure to save your current configuration, naturally.
Post Re: Screen Going Blank
Never mind I found it. Have to add
[SeatDefaults]
xserver-command=X -s 0 -dpms
to the /etc/lightdm/lightdm.conf file
How do I use minicom to issue the resetConfig on RCP's command line interface?
Anyone know how to do this?
Hi, Sorry for the late reply.
Ensuring the app is not running, run minicom on linux and configure it to connect to /dev/ttyACM0.
Once connected, press <enter> to see a list of CLI options.
type 'resetConfig' and press enter. This will reset to factory defaults.
