Thanks for the follow up. Unfortunately, the Application log only has information pertaining to the app itself; it does not have information about SD logging.
Auto-controlling SD logging is a feature we're releasing in the 2.13.x firmware, and will make it much more reliable to create data logs.
Once you load the 2.13.0 firmware, you'll be able to use the SD logging screen shown here:
https://www.autosportlabs.com/racecaptu ... available/
One thing you'll need to do is *remove* any lua scripting you have around automatic logging control, as the firmware will handle it internally.
When you have a chance to try that out, let us know how it works!
