More than four analogX on a single CAN bus
Post More than four analogX on a single CAN bus
Looking at the wiki I see the base address and offset configuration that allows 4 analogX modules on a single CAN bus.
Skimming through code on github I see
Code:
 // CANFilter shiftx2_can_filter = {1, 0, 1, 0, 0x000E3700, 0x1FFFFF00}; // g_can_base_address, ANALOGX_CAN_FILTER_MASK
offset |= palReadPad(GPIOA, ADR1_ADDRESS_PORT) == PAL_HIGH ? 0x01 : 0x00;
offset |= palReadPad(GPIOA, ADR2_ADDRESS_PORT) == PAL_HIGH ? 0x02 : 0x00;
Are there limitations that would prevent loading a revised firmware to analogX, with different base address or offset, values so that more than 4 modules could be on the same CAN bus?
Cheers
John
