Reply to topic Page 8 of 8
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8
Raspberry Pi support - enables a hard-wired, dedicated dash
That's right. We will post here and everywhere else when it's ready for beta test.
Fresh Linux user here.
Raspberry Pi 3 B+, official 7 in display, light image, downloaded app version 1.16.3...
Everything is done according to manuals
When I try to start the app with run_racecapture.sh it tries to do something for couple of seconds (new line appears) but then nothing happens and it just returns to normal command prompt
Where should I start with this?
Be sure you download the exact filename from the website:
https://autosportlabs-software.s3-us-west-2.amazonaws.com/racecapture_linux_raspberrypi__1.16.3.tar.bz2
Sometimes people hand type this in and not notice the double underscores in the name.
Also double check that you're on a Pi3, the current release does not work on a Pi4.
Let us know how it works for you!
It does seem like it should work on Pi4
https://kivy.readthedocs.io/en/master/installation/installation-rpi.html
But, it seems like this requires Kivy 1.11.
I can't seem to find a file in the racecapture tarball to change these "environmental variables" to the window and GL backend for RPi4. Which Kivy is bundled in the tarball?
Yes, those instructions were provided by us to the Kivy team, which then published them.
To support the Pi 4 requires a new build of the RC app + a custom build of the SDL library, something that's not easily packaged in an installer. As a result we may make our distribution to properly support it.
