Which virtual keyboard are people using on the touch screen with the Raspberry Pi RaceCapture app? It would be kind of nice to have a virtual keyboard for adjusting simple stuff like min/max ranges and warning prompts.
I'm looking for something like when running RaceCapture app on a Windows tablet, where if you enter a text dialog box the virtual keyboard automatically pops up. Or, you can enable the virtual keyboard through system tray at the bottom.
I tried installing kvkbd, but got a bunch of 404 errors. Seems like the package is no longer available.
I installed florence, but it doesn't seem to work with the RaceCapture kivy app.
Haven't tried matchbox-keyboard or onboard.
Solved: virtual keyboard for Raspberry Pi RaceCapture app?
How to
got it, just change the kivy configuration file
and add "multi" in the keyboard mode, so it looks like:
Reference:
https://kivy.org/doc/stable/api-kivy.config.html
Note, I also have florence virtual keyboard installed, so I don't know if this works without florence being installed. But, it's probably a good idea to have a virtual keyboard installed for Raspberry Pi anyhow.
sudo nano /home/pi/.kivy/config.iniCode: Select all
keyboard_mode = multihttps://kivy.org/doc/stable/api-kivy.config.html
