36-1 Electronic Trigger Wheel Emulation
What would you like to see? Post your suggestions here!
BRUCEROE
Post by BRUCEROE »
That is right, thanks for the correction. The EDIS is wired for a 36-1 wheel, sorry about the mistypes. Bruce Roe
cribbj
Re: 36-1 Electronic Trigger Wheel Emulation
Post by cribbj »
Hey guys haven't been on here in ages, and it's been almost as long since I played with ignitions & dynos :)
Here's my question, I'm needing to build a bench tester for six cylinder waste spark ignitions and I want to use the EDIS6 and a JimStim.
Does anyone have experience with this and have a schematic or wiring diagram to wire the two up? I know this is pretty fundamental, but I recall many years ago that I did this and ran into some issues. Just can't remember what they were.....
TIA as always!
Over the hill, low on compression, and sometimes not firing on all cylinders, just like my cars.
I created a bench tester that actually has a spinning 36-1 wheel. We don't have a use for it anymore, would you be interested in it?
