Megajolt Lite Jr & ECC-IV
4600cc
Post by 4600cc »
Can Megajolt Lite Jr work with ford ECC-IV? I have a 1995 Crown Victoria with ECC-IV and EDIS 8, it uses mass air sensor thought, not manifold absolute pressure.
AL
Paratime
Runnin Rich
Post by Paratime »
The MegaJolt does not control any fuel injection systems. The fuel injection computer from Ford controls both the fuel and the spark timing. It must have input from the EDIS module to synchronize the fuel injection. If you want to use the Ford fuel injection portion only, and have the MegaJolt run the spark timing, the Ford computer will set a Check Engine light and probably go into Open Loop limp mode when the computer discovers it can no longer control the timing.
