'91 Mustang dual plug EDIS
dbc105
Post by dbc105 »
I have a wrecked '91 4 cylinder Mustang. I would like to put the direct fire from it onto my SVO, single plug/distibutor engine. The '91 has 2 plugs per cylinder and 2 coil packs like a V8. I guess the duel plugs fire at the same time. Can I use the EDIS module and just fire 1 coil pack and not hook anything to the other side or will I need to get a module for a single setup?
David Clark
[email protected]
Paratime
Pokey Pony
Post by Paratime »
91-93 Mustang 2.3l dual plug systems use a module that is not directly compatible with the MegaJolt. The coil packs are OK.
dbc105
thanks for the info. looking
Post by dbc105 »
thanks for the info. looking at another post it looks as though an Escort or Tracer should have the module I need. that should be easy to find, Ford built a million Escorts.
David
dbc105
