RPM reading when engine turned off
Post RPM reading when engine turned off
On flashing a working chip to the beta version and only connected to laptop I get an error when running java program which states RPM values out of range. I ignore this error and go into setting and notice the RPM value is 457. Any ideas before I plug into car. On flashing chip to old firmware its zero.
Post Did this repeatedly happen wh
Did this repeatedly happen when you would run the tuning program? You should be able to read and write the configuration with no problems.
Brent
Founder, Autosport Labs
Post Yes
Sorry for long delay in writting reply.
Every time I switch off and on again the RPM reads around 400. When running does not seam a problem it appears normal. I will say the beta versions appears much better.
