Triggerwheel made out of aluminium?
knastenrad
Post by knastenrad »
Would it work with a alu trigger wheel(non magnetic) or is the steel(magnetic) needed to produce the signal
I have considered to CNC machine a pulley with trigger wheel in one unit , made from aluminium.
If it works as a inductive sensor it would work i asume , but if it depends on the steel wheel and the coil inside the VR sensor to produce the signal ... i would not waste the time :)
Oliver Sedlacek
It has to be ferrous, i.e.
Post by Oliver Sedlacek »
It has to be ferrous, i.e. steel.
4600cc
The teeth have to be
Post by 4600cc »
The teeth have to be magnetic. I would imagine aluminum coated in something will do, or steel screws inside those teeth. I bet he has a CNC machine!!!!!!!!
knastenrad
Ok Thats what i
Ok
Thats what i suspected..
I do not have my own CNC .. but it is available :)
