More help please....
Jenko
Post by Jenko »
After being inturrupted with my MJ install (baby decided to arrive a few weeks too soon), I'm hoping I can get a few hours in this coming weekend....HOWEVER:
I've now checked for firing of the plugs by grounding them on the block.....and this all seems to work perfectly when I crank the engine....but, I still have no ignition whenthe plugs are in.....My guess at this point is there is something fundementally wrong with the timing, but I can't work out what I could have done wrong....I get no firing at all!...
What have I checked:
Toothed wheel - missing tooth is 90 degress before TDC - Check
Plugs sparking - Check
Questions:
Does it matter where the VR sensor is in relation to the wheel - by this I don't mean the distance, but the actual location (i.e. does it need to be 90 degs to TDC) - I didn't think so but can someone confirm.
The coil pack has 1, 2,3,4 ona a sticker - I assume this is the cylinder they need to be connected, and not the firing order?????.........
Any suggestions on where to go from here are most welcome - Thanks.
PAul.
You might have your trigger wheel / sensor setup incorrectly.
Ford EDIS requires the VR sensor to be X degrees before the Missing tooth, when the engine is at TDC for cylinder #1. See the info here (there's an animated illustration which should help visualize this...)
http://www.autosportlabs.net/index.php? ... nformation
In your case, X = 90 degrees.
For the coil pack- the labels are correct providing you didn't reverse the coil pack connectors on the EDIS module. Figuring this out correctly is easy for the EDIS-4, as you just have to flip the connections.
Let us know what you find out,
Jenko
Post by Jenko »
brentp wrote:You might have your trigger wheel / sensor setup incorrectly.
Many thanks......I missed this totally, and am sure this must be the problem.........I simply cut out the missing tooth 90 BTDC, and fitted the VR where I could, I did not realise position was important!....I feel like a right walley!......
Anyway, It looks like all I need to do is tweek the toothed wheel to put it right as my engine is a 4 cylinder cllock wise rotation (ford CVH)............
Thanks again.
Paul.
Conrad
Can u move wheel stil ?
Post by Conrad »
If u stil can rotate wheel
Put enjin @ TDC on cyl 1
Move wheel round until sensor 90 deg before missing tooth problem sorted
Jenko
Re: Can u move wheel stil ?
Post by Jenko »
Conrad wrote:If u stil can rotate wheel
Got it......Going to give it a go on the weekend....Thanks
Paul.
