Lathyrus 7 running under Megajolt
david jenkins
Post by david jenkins »
Here's my car, now running under Megajolt (maps still under development). It's built to Ron Champion's 'Locost' design.
It has a 1660cc Ford Kent (crossflow) engine, a weber 32/36 DGV downdraught carb, and a fast road cam.
Keeps me occupied! :P
[/img]
Conrad
What stage of development is your map
Post by Conrad »
If it is running ok please share it
what is your max advance
what is your "max vaxuum advance" top line - botom line
Thanks Conrad
david jenkins
Conrad,
I wouldn't like to publish my map at the moment - it's only a 2D one, and is still under development. It is a safe starting point however, and is certainly no worse than fitting a racing mechanical distributor without vacuum advance. The MAP range is 20 to 100; advance at 800rpm is 12 degrees, to 36 degrees at max revs (6200rpm).
At the moment I'm trying to make a device for listening for any pre-ignition - as you can see from the picture, when on the move I can't hear the engine itself because of wind noise and exhaust roar! I'll be using a knock sensor, amplifier and noise-reducing headphones so that I can hear the 'pinking' where my development map is too far advanced. This work is still in the very early stages.
regards,
David
Conrad
Knock Amplifier
Post by Conrad »
glue an small piezo microfone (mayby pc boom type microfone ?) to an big batery clamp those u use for jumper cables bring wires from mic into car with an small amplifier (try laptop mic in port ?) conected to a good set of earphones must be able to cover ears
i did not try this but i hear it work
for the fun of it if u use laptop u can record it via recording software !
Goodluck
Conrad
david jenkins
I got a few ideas from this link. There's even a link to a recording of pre-ignition!
I already have some ear defenders with an amplified input, so I'll connect those to a knock detector that will be bolted to the engine block (these knock detectors are only an electret microphone in a very tough package). I've got all the bits, so I just need to put them all together.
cheers,
David
