Megajolt has been running on my car for just about 4k miles. Within the last 200 miles the car has developed a misfire at around 4900rpms which produces a substantial backfire.
I have swapped ignition modules- still backfires
Run the car with MJLJ disconnected- still backfires
Checked the plug wires for leaking spark- none found
Cleaned ground wire connections- still backfires
So I know this problem is not the module or the MJLJ. Everytime I try to datalog this event the car runs perfectly.
The car:
1969 MGB
bored, camed, ported head, N/A, stock HS4 carbs with reprofiled needles
