Loading Dual Maps
Edwardatherton
Loading Dual Maps
Post by Edwardatherton »
I assume that if I want to upload two maps I need to wire the options switch. When connected to the computer if I flick the switch it should then display the other map...
Correct? :D or Not? :(
Land Rover 1957 S1 88" 2.5 petrol/LPG
MartinM
Post by MartinM »
Yes ...
If you check Enable Dual Ignition Config on the Tools|Global Controller Options menu item
and
If you set When Ignition Config Switched to be "Auto-read configuration" on the Tools|Configurator Options menu item
