Earthing the shielded cable
Beakster
Post by Beakster »
I have the shielded cable for the EDIS to VR and EDIS to MJ.
The diagram shows the shield of the VR sensor connected to pin 7 of the EDIS, while the shield of the cable to the MJ is connected to pin 7 and earth.
The effectively means that both cables shields are connected to pin 7 and earth. I have just made up my loom and only connected both shields to pin 7, as that was my initial understanding of the reason for that pin, to provide a shield earth.
Is there any reason to also earth pin 7? This effectively jumpers pins 7 and 9. If this was required why wouldn't it be done inside the EDIS?
-Chris
rbalmford
Post by rbalmford »
Hi Chris,
I checked my EDIS4 unit with an ohmmeter and found pins 9, 7 and 4 are all connected together internally, so I don't believe you need to additionally earth pin 7 (or 4). I have done as you have and used pin 7/4 for the shields, and works just fine.
Rich
Beakster
Post by Beakster »
Thanks Rich,
For neatness, if I was doing it again I would use pin 4 for one shield, and for the other.
Cheers
-Chris
Ken555
Post by Ken555 »
Is this a valid set-up ?
New Diagram
New Diagram
MartinM
Post by MartinM »
Looks good to me....
Ken555
Post by Ken555 »
Lets hope so, because it's too late now.
