Vauxhall 1.8i 8v w/ twin Dellortos
Post Vauxhall 1.8i 8v w/ twin Dellortos
(Originally posted by PioneerX)
Engine Mfg: Vauxhall
Engine Code: Unknown
Cylinders: 4
Displacement (cc): 1800
Rev Limit: Unknown
TPS or MAP: MAP
Boosted or Normally Aspirated: Normally Aspirated
If Boosted- max Pressure (KPa):
Modifications: Twin Dellortos
Chassis:
Notes: "Vauxhall 1.8i 8v (Vauxhall Carlton) - Injection removed - Twin Dellortos - Running MAP sensor."
Vauxhall 18SE - 1800 8v.mjlj
 Description:
Download
 Filename:  Vauxhall 18SE - 1800 8v.mjlj
 Filesize:  794 Bytes
 Downloaded:  1028 Time(s)
hi,
i have the 1600cc version of this engine, will this map be a good starting point for the engine i have??
thanks in advance
andy
View user's profile Send private message MSN Messenger
Post trigger wheel
Hi what did you use for a trigger wheel on the vauxhall the fitted trigger wheel has 72 teeth ?
cheers
