Crankshaft Pulley Balancing
AndyGT6
Post by AndyGT6 »
I am about to get the machining done on my crank pulley extension and trigger wheel so I can weld them together. Is it advisable to get the assembly balanced before refitting to my engine, or will it be ok as it is. I initially thought that as the work will be done on a lathe so the trigger wheel has no run out once it is mounted, it should be reasonably balanced from the outset. I look forward to any replies.
Andy
fikus01
Post by fikus01 »
personally id get it checked just to satisfy my over worries mind!! whats to say it was balanced properly at the factory!
DO SOMETHING SILLY, TURBO AN 1100CC METRO :)
Oliver Sedlacek
Post by Oliver Sedlacek »
I'd say that balancing isn't strictly necessary, but it is nice to have a smooth engine. As the original pulleys aren't usually well balanced, it will make a difference, and you might as well do it after the trigger wheel has been mounted.
mwman
Post by mwman »
Remember the front pully has a rubber damper built in, don't use excesive heat!!
I bolted mine to the fan mount.
Simon
Salamander
Post by Salamander »
Hello, my crankshaft -flywheel-dumpers the check balance was perfect, all the components are new, steering wheel also no have problems of balancing.
Tomorrow upload photos whit the trigerwheel
sorry my bad english :oops:
AndyGT6
Post by AndyGT6 »
Thank you for the replies, I think I'll take a chance and fit the trigger wheel as it is, if I detect any vibration then I'll get it balanced. The pulley extension and pulley/damper have been separated as the extension locates on two pegs, so there is no worries of heat affecting the damper. Attached is a picture of the extension and trigger wheel, I'll be doing the welding next week hopefully.
Andy
Salamander
Andy:
you machined the trigger wheel on CNC?
AndyGT6
Post by AndyGT6 »
The trigger wheel was purchased from Triggerwheels.com, one of my colleagues in work enlarged the original 1/2inch pilot hole on a lathe.
Andy
