Hello,
I would like to introduce my datsun 260Z Projetct.
240Z Motor with 10.5:1 compression
Triple weber (45mm) with airbox
Janspeed header
Kent Cam with 290 degree
Edis Ignition with Megajolt
The new motor is nearly ready to install, but for the first stage I wanted the edis runing.
To be continued
Rainer
Datsun 260Z Projekt
Datsun 260Z Projekt
- Ford coilpack with custom ignition wires.
- coilpack.jpg (79.26 KiB) Viewed 7591 times
- Custom VR sensor bracket.
Trigger wheel is from trigger-wheels.com - VR_sensor.jpg (87 KiB) Viewed 7592 times
some more pictures
the actual state with original engine
- sideview.jpg (45.26 KiB) Viewed 7590 times
- original engine
- recent_engine.jpg (110.51 KiB) Viewed 7590 times
