MSD Ignition
KLAS
MSD Ignition
Post by KLAS »
i think i am not the only one thinking of how a MSD box can be fitted.
i found that MSD offers a DIS-2 box, PN 62112, thats made for this job, they say.
http://www.msdignition.com/pdf/frm25956 ... m25956.pdf
maybe someone could check it out if this will work with MJLJ
its not realy cheap so i don't know if its worth a try[/url]
aarc240
Post by aarc240 »
It does essentially the same job as MJLJ at a cosiderably higher price so why would you fit it WITH an MJLJ?
KLAS
Post by KLAS »
i won't fit it at all, to expensive.
but i still like the idea of a CDI, but i don't know a cheap way to fit one with MJLJ
aarc240
Post by aarc240 »
I don't think there is any easy way of doing that unless someone wants to develop an equivalent for EDIS with CDI output.
Not a trivial task!
brad m
Post by brad m »
the DIS-2 and -4 units are not like the MJLJ, they are simply a multi coil versoin of the 6AL. in that it has Multi spark CDI and rev limiting. it only has a few extra things list nitrous retard and soft limiter as well as a hard limiter.
It's not a programable ignition controler like the MJLJ
