loom
widebodyhachi
loom
Post by widebodyhachi »
trying to figure out how to modify my loom to meet up with MJLJ, got a 4AGE any body help please
Hello,
Have you seen the installation guide? The wiring diagram illustrates how to connect the EDIS, MJLJ, coilpacks and crank sensors.
http://www.autosportlabs.net/MJLJ_V3_ve ... tion_guide
Aside from finding a suitable source of +12v power, there isn't a need to integrate it into your original factory wiring harness.
Are you running carbs or the factory Fuel Injection? If you're running carbs then most of the engine wiring harness would go away.
widebodyhachi
yeah running carbs but its things like how o I wire in factory dizzy
david jenkins
Post by david jenkins »
Um - you probably don't need the factory dizzy!
Once you've fitted the trigger wheel, sensor and MJ control box the dizzy can be removed (or becomes redundant anyway).
David
